Need help with my swap.....
Old Jan 1, 2014 | 02:59 PM
efsedan26's Avatar
Default Need help with my swap.....
i have a 95 crv b20 in my 1990 ef sedan. my rpms are around 1500 at idle. Old owner said something about the tps wiring witch cable do i need to change the hole tps wiring.. Could it be the ecu or something all help will be appreciated. Thanks in advance and Happy New Year!!!!!!
Old Jan 1, 2014 | 05:53 PM
myefhasaname's Avatar
Default Re: Need help with my swap.....
is it at 1500 before or after (both?) warming up?
have you tried adjust the idle screw on the throttle body?
Old Jan 2, 2014 | 10:10 AM
efsedan26's Avatar
Both and yes I tried and no luck
Old Jan 2, 2014 | 10:29 AM
Freemananana's Avatar
Vacuum leak.
Old Jan 2, 2014 | 10:30 AM
BLU CIVIC's Avatar
Track Advocate
cleaned Idle Air Control Valve (IACV)?
SAfire
Jan 25, 2009 11:51 PM
ITR EG
Apr 12, 2008 09:29 PM
EJ7_1998
Mar 6, 2007 08:21 PM
B_CRUZ!
15
Dec 19, 2002 02:33 PM
93H22A
Nov 4, 2001 02:44 PM
