Mid pipe crack repairable??
Old Dec 31, 2013 | 11:40 AM
hatch_'s Avatar
Default Mid pipe crack repairable??
My mid pipe cracked right where it connects to the resonator. Would a muffler shop be able to weld it back together or should I just find a used midpipe? Also, is it okay to drive with just the headers for several days? Some people say its okay and others sayi can ruin the valves. Thanks in advance.
Old Jan 2, 2014 | 06:07 AM
turbodcxbro's Avatar
Default Re: Mid pipe crack repairable??
A good exhaust shop can fix it, and running just open header won't hurt anything.. ever seen a real race car?
Old Jan 5, 2014 | 02:20 PM
Engloid's Avatar
OG Fabricator
You won't damage valves with open headers. It's 100% myth. Exhaust piping has a few purposes:
1) Route sound to the back of the car where it is quieter while in the car
2) Route exhaust gasses to the back, where it gets the least smoke on the car
3) Route HEAT away from the engine.
Number 3 is most important. If you run a car without any manifold or header, it will not route heat away from the head. The head will then get hot and valve damage, and much other damage, can result.
Think about dragsters...with a 3-4" open header that's ony about a foot long. It works just fine because it's enough to get heat away from the engine.
Old Jan 6, 2014 | 05:09 PM
1upmoto's Avatar
Running open headers on a car that is tuned for it is a little different than just running open headers when you are tuned for a full exhaust. It will cause you to run lean, which "can" damage valves.
Old Jan 6, 2014 | 05:57 PM
Engloid's Avatar
OG Fabricator
What controls your amount of fuel into the cylinders? Not the velocity of exhaust, or backpressure.
Randomnoob
Sep 15, 2018 03:39 PM
hatch_
Jan 1, 2014 08:34 AM
CivicSiDriver02
Dec 19, 2005 06:54 PM
EJ1 wilcox
Dec 15, 2005 04:56 PM
SpeedMachine
Mar 13, 2005 01:16 PM
