91 honda accord check engine light
Old Dec 31, 2013 | 08:32 AM
sammi's accord's Avatar
Icon6 91 honda accord check engine light
The check engine light comes on while decellerating. It stays on then, but is off when the car is next started. It sometimes stays off for days but then comes back. The car seems to drive fine. The only other symptom is a hot smell after driving. You can't smell it inside the car but you can smell it near the front of the car when you get out. It is not a burning smell, more like a hot iron.the temp gauge never goes above half and the radiator does not need topping up more than usual. Is it true that an older car like this has error codes and if so how would you access it
Old Dec 31, 2013 | 09:54 AM
GhostAccord's Avatar
Default Re: 91 honda accord check engine light
This procedure works on any 90-97 Accord with the SCS connector. 90-93 SCS connector located behind the passenger side kick panel and the 94-97 is located under the glove box.
Corresponding diagnostic trouble codes;
1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping
* not 94-95
6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
* invalid code for non-equipped EGR valve vehicles
13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
15 Ignition Output Signal missing or defective ignition output signal
16 Fuel Injector System defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector defective circuit or unplugged / defective sensor
21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23 KS (Knock Sensor) defective circuit or unplugged / defective sensor
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor
* invalid code for 1996
31 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41 Primary Oxygen Sensor - Heater circuit malfunction
43 Fuel Supply System defective or malfunctioning fuel supply system
Amanda Michelle
Mar 13, 2018 02:22 PM
junior91hondaac
Jun 16, 2013 05:40 PM
rommersk
Nov 2, 2007 04:17 AM
zak88lx
Jun 5, 2007 01:33 PM
