Design Merge collector for TwinScroll EVO
Old Dec 30, 2013 | 02:41 PM
Walterronny's Avatar
Default Design Merge collector for TwinScroll EVO
Hi there! pretty sure this would help to other ones and i hope to help it to me too..
well i wasted a lot of tubes today trying to get the best angle for make merge collector...tried with CAD and got that 20 degress will works good..i was wondering what angle do you use for make these..i know would be needed to port a bit for fit with these very weird twinscroll...
what do you think?
Using sch10 1.5
Old Jan 1, 2014 | 07:00 PM
Default Re: Design Merge collector for TwinScroll EVO
well, i did it.. i will post more pics soon.
hope this help to someone.
W.R
Old Jan 1, 2014 | 08:01 PM
Alex L.'s Avatar
Looks good man, in for more pics!
Old Jan 1, 2014 | 08:27 PM
FabChild's Avatar
Looks Good!
Old Jan 2, 2014 | 02:02 PM
lopez286's Avatar
Keep those updates coming
Old Jan 2, 2014 | 03:06 PM
Tried today but finally looks like i need more clearance still..im designing another merge for test it tomorrow.. noticed too that making a replacement Evo manifold using 1.5sch10 will be too tight! 1 1/4 would be easier to build!
Old Jan 3, 2014 | 05:13 AM
HellaFab's Avatar
you might need a few tight radius bends. they are pretty pricey though.
Old Jan 3, 2014 | 01:01 PM
tested it today and definitely it's a pain to buil this replacement using 1.5".. it's needed tight radius elbows also i have a problem with one hole, bolt doesnt insert , that could be solved with any problem i think ,the big problem is with 3 port.., monday i will call to supplier and ask for 1.25" sch10 pipe, now i get why almost everything build replacement in that size..here some pictures.. i was thinking even to make a pie cuts but pretty sure it will not fits properly..
i tried to make that runner in the other side but it's needed tight elbows..
Old Jan 8, 2014 | 01:45 PM
this is what i made so far..really hard using long radius elbow..i hope this days a local supplier can sell tighr radious elbows but would be for next manifols already! got too 1.25sch10 for make anothers..
What flow do you use for backpurge?
Old Jan 8, 2014 | 03:45 PM
abnaasefmb's Avatar
Looking good
Old Jan 8, 2014 | 06:23 PM
lopez286's Avatar
so did the 20 degrees work well for the collector
Old Jan 9, 2014 | 08:37 AM
HellaFab's Avatar
That doesn't look that bad.
Your fixture doesn't look that solid to be building manifolds off of though. I did that once early on and it shifted angle just a hair and threw everything off. Not trying to be critical, just helpful if you are building it to use existing downstream parts.
Old Jan 9, 2014 | 01:26 PM
what you means with "fixture"?
more pictures, need to get better fitting yet and more works, definitelly this is a really hard manifold to build with long radious....
not finish yet..also i will have to port it once everything is cleaned and welded.
P.S i have to fabricate too tube for replace upper radiator hose.
Old Jan 9, 2014 | 02:47 PM
hoochhenry's Avatar
looking real good ,keep us posted good job
Old Jan 15, 2014 | 04:14 PM
this is how 1.25 looks like.. (a bit easy).
Found a supplier with some pipes short radius 1.5" 90 degrees, that's the way to do a 1.5 replacement evo manifold!. i ordered some pipes to stock these here.
i was testing my back purge setup.. the key is how good you bevel pipes for get best penetration, also i need to test more different flow for back purge..
Hope this help
Old Jan 21, 2014 | 03:54 PM
1.25" done, i will post pics for 1.5 when it's done.
Old Jan 21, 2014 | 07:53 PM
McRussellPants's Avatar
Not the right firing order mang.
1-3-4-2
1 and 4 get paired.
2 and 3 get paired.
Old Jan 21, 2014 | 11:55 PM
I was thinking about that but finally based in some other manifolds in the market that works good so we will see it how good it works.
Old Jan 22, 2014 | 02:34 AM
abnaasefmb's Avatar
Looks good.
Old Jan 29, 2014 | 01:31 PM
1-3-4-2
1 and 4 get paired.
2 and 3 get paired.
you finally are right, i did not noticed everything good some designs , just changed some angles and that confused to me, i will make another one with the right firing order!.
RCautoworks
Welding / Fabrication
18
Jun 23, 2006 01:02 PM
TIGboy
Dec 17, 2005 10:14 PM
fabnewb
20
Jan 6, 2005 02:43 PM
Chris93Si
Nov 1, 2003 01:59 AM
legendboy
Sep 22, 2002 07:48 PM
