door alignment
When I close either door on my si hatch it appears as if the doors aren't closed all the way. The back part of the door sticks out about an 1/8 inch from the rear quarter panel. I thought it might just be alignment, but the side lines appear to be fine, and the doors seem to work correctly (except the pass. side inner handle, but that's a whole other problem). Does anyone know how I can correct this?
the door latch in the door jamb should be moved inward. I had this same problem and it would always come loose a couple weeks after adjusting. About 6 months ago I reset it with some jb weld and haven't had a problem since.
