front turn signals dont work rear do???
Old Dec 29, 2013 | 03:39 PM
crookson speed's Avatar
Default front turn signals dont work rear do???
ok so i have this problem where the front turn signals dont work on my 1990 civic si with a b swap. the blinker blinks fast and i put a volt meter in the plug and im getting a 0 to 3 to 4 volts on and off like i should? but then i plug in my bulb and socket nothing. is it the icu or the relay or the switch. what do you guys think and thanks.
Old Dec 29, 2013 | 04:25 PM
zrickety's Avatar
Default Re: front turn signals dont work rear do???
Probably the ICU behind the fuse box. You should be getting about 12 volts.
Old Dec 29, 2013 | 05:33 PM
sory 12 volts to the icu?
Old Jan 2, 2014 | 10:45 AM
ok i replaced the icu and it does the same exact thing im goint to check the wiring .
Old Jan 2, 2014 | 07:07 PM
myefhasaname's Avatar
Do all the lights function during use of the hazard button?
Does the hazard button work at all?
Its been a little while since I had to trouble shoot a similar problem. Check the basics. Make sure you are getting 12v at the turn signals and the bulbs are good. After that check around the hazard switch I remember there being something unexpected on how the signal wires run through that hazard switch. I want to say I had the same symptoms and it ended up being the hazard switch got disconnected while re-wiring my gauges.
Hope that helps.
slammed4dreg
26
Nov 16, 2014 04:24 PM
kwalzy
Mar 19, 2008 12:12 PM
si90rex
Aug 10, 2006 09:54 AM
jedubz
Aug 18, 2005 12:56 PM
ErikDaGenErik
Jan 20, 2003 01:37 AM
