Connecting Amp Power cable through Firewall 1998 Honda Accord V6
Old Dec 29, 2013 | 02:03 PM
Danntek's Avatar
Default Connecting Amp Power cable through Firewall 1998 Honda Accord V6
Where would the best place to put my wire through the firewall to power my amp. I am trying not to drill holes through my firewall. I can't seem to find rubber thing to shove the wires through. It's a 1998 Honda Accord LX V6.
Old Dec 29, 2013 | 02:15 PM
ej7attack's Avatar
Default Re: Connecting Amp Power cable through Firewall 1998 Honda Accord V6
look harder, there is something there....had subs and amp in my accord. make a small hole through existing wire loom grommet. or take out a plastic grommet.
Old Dec 29, 2013 | 02:43 PM
Danntek's Avatar
Would this work? I found it near the passenger firewall area.
But I couldn't find where it lead to under the passenger area.
Would I have to remove the glove department and maybe it'll be over there?
Old Dec 29, 2013 | 03:28 PM
Zak325's Avatar
The A/c pipes lead to the area behind the center console/glovebox area, so most likely thats where this will lead. It is quite crammed back there but yes I think you can make it work through there
Old Dec 30, 2013 | 04:46 AM
ej7attack's Avatar
if not there, just a little below there with the other wires and make a small slit to push the wire through.
Old Dec 30, 2013 | 05:12 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
and make sure you protect the wire, and fuse it right next to the battery, I mean as close to the battery as you can get it
ALDJ253
Mar 6, 2014 07:25 PM
gelmera
May 17, 2010 09:13 AM
DRKSol
Audio / Security / Video
May 27, 2005 11:08 AM
raguripper
Jun 30, 2003 05:11 PM
