gen 4 prelude.. mods for faster steering. dirt racing
Old Dec 29, 2013 | 08:28 AM
JP3's Avatar
JP3
Default gen 4 prelude.. mods for faster steering. dirt racing
Ok boys. I'm going to be racing this car on a dirt oval. Currently the car is roughly 3 turns lock to lock. I would like to cut that down to 2.5 or less lock to lock. Steering quickeners are against the rules for the class so they aren't a option. I found a thread that said I could possibly drill a hole in the steering knuckle closer to the hub than the stock hole and attach the tierod ends to the new hole. Will this work? If so what kind of results should I expect? Is there anything else I can do? Possibly change the gearing inside the box itself? Any suggestions are welcomed.
Old Dec 29, 2013 | 10:38 AM
JP3's Avatar
JP3
Default Re: gen 4 prelude.. mods for faster steering. dirt racing
Could also use some ideas on how to take the push out of the car. We are already going to run slicker rear tires with like 40-45 psi so the rear slides around. Put more weight on the left front. Remove front sway bar. Run more weight on left rear. Maybe try to preload the rear sway bar to further loosen the rear. Is there anything else I can do to help this car turn and stay hooked up on dirt?. Ohh also going to run as much camber as I can get out of it and set the front toe way in and rear toe way out. Any other ideas?
mills7x
Jun 6, 2011 04:51 PM
6SpeedTA95
Honda Civic (2006 - 2015)
56
Aug 17, 2009 06:39 AM
FearDisH22a4
Jun 21, 2009 04:26 AM
chinoty
Suspension & Brakes
Jan 27, 2007 04:04 PM
ScareyH22A
15
Oct 24, 2005 05:37 PM
