Suspension & Brakes Theory, alignment, spring rates....
DC2 suspension on EG?
Old Dec 28, 2013 | 01:32 PM
dandurance's Avatar
Default DC2 suspension on EG?
Hey!!
I'm looking to buy an EG in the coming weeks. A friend has suggested Integra DC2 96-00 suspension parts can be fitted directly to the EG without having to modify anything.
1.) Can the DC2 suspension be fitted? (What components? Any extra things needed?)
2.) Is there any difference between the 2 OEM setups?
I've had a look on a number of forums without any luck to my questions. If you could point me in the right direction it would be much appreciated.
Cheers!
Dan
Old Dec 28, 2013 | 04:34 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: DC2 suspension on EG?
Everything on my eg suspension wise came from a teg. Control arms, coilovers, brakes
Old Dec 28, 2013 | 04:42 PM
rvn2svn's Avatar
Any 94 and newer integra suspension piece is interchangeable with the eg chassis. Not sure where you checked for info... Can't get more "common knowledge" than this. There isn't any benefit to integra suspension besides rear discs.
Old Dec 28, 2013 | 11:13 PM
Tyson's Avatar
x2
Old Dec 29, 2013 | 05:16 AM
dandurance's Avatar
Thanks for your input guys! Definitely got more of an idea now.
So Integra suspension is basically the same as the EG, but with the ability to fit rear discs?
Old Dec 29, 2013 | 02:29 PM
adam_7422's Avatar
I was also wondering the same. Thanks
Old Dec 29, 2013 | 03:08 PM
Emeraldbomber's Avatar
Yes
Old Dec 30, 2013 | 03:43 AM
rvn2svn's Avatar
Yes. Integras use the same trailing arm as the civic in the rear, except they have discs instead of drums. It's a straight swap. Unbolt from integra. bolt onto civic.
H.I CTR
May 1, 2009 07:01 AM
Boostn B20
Aug 21, 2008 04:45 AM
Nospace
Suspension & Brakes
Jan 9, 2006 02:55 AM
flatline
Aug 18, 2003 08:41 PM
