HELPPPP civic 2000 model Swap D15B 3stage V-tec came with its CVT Trans ECU P2J-J62
Old Dec 27, 2013 | 12:42 PM
Mohsin Univrsal's Avatar
Default HELPPPP civic 2000 model Swap D15B 3stage V-tec came with its CVT Trans ECU P2J-J62
i need help firends
i have honda civic 2000 i m a self Auto mechanic recently swapped D15B 3stage Vtec engine in it.
engine came with its CVT Auto Transmission and the ecu P2J-J62 which is an auto ecu .
engine swapped succesfully no fault codes but the problem is with cvt transmission wiring and the cvt wires are not connected anywhere
i have no idea where to connect them because transmission is not working does it require a TCM ??? or what any help will be appreciated and i will be very thankful let me out of this problem i want to use it with its auto cvt transmission so it can perform well thank you.
Someone told me cvt has a TCM separately if it is like that so Which TCM and how would it connect with p2j ??
Desean Brown
Jan 13, 2019 07:55 PM
98savage
May 2, 2007 09:01 PM
darkshadowcivic
Dec 20, 2004 11:58 AM
wronghand
Jun 6, 2002 04:53 PM
H22ACiViC
Feb 13, 2002 07:05 PM
