H22 cam seal replacements.
I'm about to replace my camshaft seals and I dont know how to replace the seals on the timing side. I know how to replace the seals/plug on the passenger's side, what about the timing side? Remove the valve cover and timing belt cover and timing belt.. then what?
It would be best before removing the crank pulley bolt to hold the bolt and crack loose the cam sprocket bolts. Then after removing the sprockets and belt, removing the seal can be done using a seal remover tool or a screwdriver, being very careful not to scratch the camshaft. There are vids on youtube that you can use.
