95 honda accord VSS replacement -- broken mounting bolts
Old Dec 24, 2013 | 10:19 AM
atlthrasher's Avatar
Default 95 honda accord VSS replacement -- broken mounting bolts
Hi -- I was in the process of replacing my speed sensor on my 95 honda accord and both of the mounting bolts broke. The space is too tight to get the drill in to extract them.
Any good ideas on how I can extract and replace the bolts?
Thanks in advance!
Old Dec 24, 2013 | 10:54 AM
ej7attack's Avatar
Default Re: 95 honda accord VSS replacement -- broken mounting bolts
Thanks in advance!
now you need to take the one retaining bolt out, and remove the whole assy.
Old Dec 24, 2013 | 11:07 AM
Thanks -- that's kinda what I figured. Is that pretty easy to put back together? I just want to make sure I'm not going to cause any bigger issues if I try this as a DIY...
It it as straight forward as one bolt to remove, slide it out and it should slide right back in?
Thanks in advance!
Old Dec 24, 2013 | 11:21 AM
ej7attack's Avatar
yes, one 10mm bolt. you may want to twist it back and forth before you try to pull it out.
then you should be able to work with it.
Old Dec 24, 2013 | 09:25 PM
holmesnmanny's Avatar
Be very careful putting that sole 10mm bolt back in. It's very very easy to over torque it and break the corner of the speed sensor gear assembly. You only need to gently torque it after putting the speed sensor gear assembly back in.
Jacara81
Apr 9, 2018 11:23 PM
SanjoCali
Mar 27, 2012 01:44 PM
felixb555
Jun 28, 2011 10:57 AM
Accord95Lxxx
May 11, 2005 02:34 PM
icet
May 26, 2004 12:41 PM
