Camber kit or NOT?
Like the title says. im wondering if i REALLY need a camber kit?
1993 integra daily driver
sitting on cheapbay coilover sleeves and blown struts.
I went through brand new front tires in like 2000 miles and im not even "dumped".
I researched camber kits and found nothing but controversial threads on here.
Im looking to purchase full "coilovers" for my car.
Sorry for the paragraph. BUT
DO I NEED A FRONT CAMBER KIT OR not.
Are you blind? I think you must be. It's the only way you could have missed the sticky'd thread at the top of this forum that answers your simple *** question plain as day.
What exactly made you think that creating another new thread on the subject of "do I need a camber kit" would yield a different result than all the other controversial threads you found? People haven't changed any, there is still the group that believes camber kills tires because they're misinformed and or have no real world experience to speak of. The simple fact is that when you lower a car it throws the alignment off. You add a LITTLE bit of negative camber(typically on a fwd Honda you end up in the neighborhood of -1.1 degrees in the front and -0.9 degrees in the back) , but you also induce toe out which is what actually needs correcting because it is what kills tires. I'm at -2.5 degrees in the front and -2.0 degrees in the back with adjustable camber kits and I have no abnormal tire wear to speak of because my front and rear toe figures are in check. Having access to $100,000 Hunter Engineering Hawkeye alignment systems is a really nice thing.
If you are going through a set of front tires in 2,000 miles then either your alignment is drastically out or you're running Hoosier R-comps.
Everyone is opinionated here from what i've read. So since i was in a similar situation a few months back here's what i did: lowered my car to what i wanted, got my wheels/tires on(which i don't plan on changing) and then got an alignment. Now 4 months in it is so far so good. Just keep reading if you aren't sure, that's all i did.
get an ebay camber kit. those nice shiney ones.....those are the best. after you get the camber kit installed, the blown struts will not be an issue
