Fuel Pressure Regulator.....
what are your settings on your aftermarket fuel pressure regulators?? what did you have it stock and what did you put it to, and what mods do you have for u to run what u got....... how has it affected your Q/M time????
the fuel pressure regulator isn't gonna give you hp, it will just make sure none is lost and that you don't run lean.
I believe factory is about 40-43 psi.
Nah factory is lower than that. I think factory fuel pressure on a CRX Si (for example) is around 34-38 psi. I like to bump up the pressure a psi or so for every mod I add on.
so i should add another 5 psi??? i have headers, intake, internal head work, and thats about it.......... i know ur gonna tell me to get a a/f gauge, but thats gonna be like a month before i get that.......
danno33
Dec 27, 2006 02:16 PM
