Crankshaft pulley bolt
Old Dec 22, 2013 | 12:24 PM
zsiya's Avatar
Default Crankshaft pulley bolt
The bolt on my '91 LX will not tighten. I think the belts were too tight and wallered (?) out the bolt hole. The bolt looks fine but I can't see the crank hole. I'm needing to sell this car so I don't want to sink any more money than I need too. However, I don't want to sell the car and have it break down as it drives off. Any suggestions?
Old Dec 22, 2013 | 01:33 PM
ej7attack's Avatar
Default Re: Crankshaft pulley bolt
find out why it wont thread in.
Old Dec 22, 2013 | 01:46 PM
zsiya's Avatar
I'm going to assume the threads are at least slightly stripped. Which is why it won't catch to tighten.
Old Dec 22, 2013 | 01:53 PM
10psiLsEf2's Avatar
it wont tighten?
your saying you put it in the thread hole and it just keeps spinning?
or are you saying that the bolt seems too short and doesn't reach the threads?
Old Dec 22, 2013 | 02:00 PM
zsiya's Avatar
just keeps spinning. Feels like it catches ever so slightly then spins.
Old Dec 22, 2013 | 10:12 PM
holmesnmanny's Avatar
Your pulley probably needs to be pushed on further. Take the pulley off first and see if the bolt will thread on.
Old Dec 23, 2013 | 01:29 AM
ej7attack's Avatar
hopefully those crank shaft threads aren't stripped out..................
Old Dec 23, 2013 | 07:12 AM
zsiya's Avatar
Let's say they are stripped out. What options do I have?
Old Dec 23, 2013 | 07:39 AM
tim73's Avatar
They sell, and i have used a helicoil kit, i think it if for a ford cylinder head spark plug(Check the thread pitch and size of crank bolt). It comes with a tool, which you will use to drill the hole out, then screw in the helicoil, and then you will be able to tighten the bolt down to 182Ft/Lbs
Old Dec 23, 2013 | 09:51 PM
You could always confirm that the threads are in fact bad before moving onto other options.
whitehf
12
Oct 13, 2011 08:12 AM
Midori Green
Jun 3, 2008 07:00 PM
Johnny Groovez
Sep 14, 2006 10:50 PM
DaKINE-Ek
Aug 14, 2006 05:22 PM
pureGSR
Jul 11, 2001 02:47 PM
