Civic Wont start, D16Z5 swap
Old Dec 21, 2013 | 04:47 PM
Alex_S's Avatar
Default Civic Wont start, D16Z5 swap
Hey guys, asking for a friend here.
Hes been having this problem.
The car wont start, feels like there's a grounding issue as the parking light will light up very little when turning the key, but when the light is on the fuel pump doesnt come on. But if you wiggle the key a bit sometimes you will hear the pump come on and the car will start. Only to die again after a few seconds..
He has checked, and re-soldered the Main relay.
Battery ground and Thermostat housing ground has been cleaned and checked.
Another thing is the ecu will stay on and blink even after taking the key out of the ignition? only after a few minutes you will hear a click in some relay ( dont know which ) and after that it shuts off.
Now i told him to count the blinks from the ecu, will know which codes its throwing tomorrow.
im starting to think maybe it could be the ignition switch?
anyways is there anyone that has come across this issue before?
and yes the car has worked perfectly fine for a couple of months before this happened!
Thanks in advance
Old Dec 22, 2013 | 08:50 AM
JDp0wer's Avatar
Default Re: Civic Wont start, D16Z5 swap
I would check/clean your grounds, especially the thermostat one. Then it seems like the ignition switch mine would start then die once I let go off the key.
swindian1991
May 13, 2013 07:17 PM
bryan24207
Jan 19, 2012 07:53 PM
lazylegs15
Sep 14, 2008 10:20 PM
MrPotatoeHead
16
Dec 6, 2005 02:45 PM
slow hatch
Apr 19, 2004 10:00 AM
