Is this a broken TPS?
Old Oct 28, 2002 | 08:05 AM
2000Accord5sp's Avatar
Default Is this a broken TPS?
Car: Stock 1994 Accord EX
I'm seeing two problems. Sometimes, the car will just idle extremely high 1900-2300rpms. Othertimes, it will fluctuate between 1200-1500 back and forth as if i was trying to taunt someone to race me
I don't know exactly what would cause this...could it be something to do with the throttle position sensor? Any other things you guys would suggest is the problem?
Other minor problems: I don't know if this is related but the cruise control is off when you set the speed. After setting it at a certain speed, it will always go about 3mph faster than that.
[Modified by 2000Accord5sp, 9:05 AM 10/28/2002]
Old Oct 28, 2002 | 08:43 AM
Accord94DX's Avatar
Default Re: Is this a broken TPS? (2000Accord5sp)
throwing any codes?
Old Oct 28, 2002 | 08:44 AM
Stew Pidasso's Avatar
Vaccuum leak maybe?
Old Oct 28, 2002 | 09:30 AM
John's Avatar
New User
Does the idle fluctuate when the car is cold? It could be the IAV, FICV, or perhaps a sensor as you mentioned...
Old Oct 28, 2002 | 09:38 AM
Default Re: Is this a broken TPS? (350Z but Poor)
The check engine light isn't on.
And this problem is consistent whether the car is cold or warm.
Where could i check for vacuum leaks?
Another odd thing I noticed is even though the car is stock, at low rpms and accelerating, for a second, you hear a loud sucking noise as if i had cold air intake or something. So maybe it IS a leak?
Old Oct 28, 2002 | 09:45 AM
John's Avatar
New User
Yeah, it's likely a leak. Check your vacuum hoses on your intake manifold first...
Old Oct 28, 2002 | 12:00 PM
Sure enough, I went down during lunch to check them and the problem is the hose that goes from the manifold to the valve cover. Only problem though is that it's not a loose hose, the whole metal braket that's suppose to be stuck on the manifold is broken off. I'm thinking I can use JB weld or something to keep it on there?
Old Oct 28, 2002 | 12:16 PM
carolinaACCORD's Avatar
JB Weld 0WnZ!
Old Oct 28, 2002 | 12:35 PM
Default Re: Is this a broken TPS? (carolinaACCORD)
Yea, sure beats buying a new valve cover.
Old Oct 28, 2002 | 06:31 PM
droccadnoh's Avatar
Newbie question: What is a TPS? Thanks.
Old Oct 29, 2002 | 03:55 AM
Default Re: Is this a broken TPS? (droccadnoh)
Throttle Position Sensor
legacy1644
Oct 18, 2008 12:05 AM
hurleypooper
Apr 29, 2008 08:12 PM
kootari
Feb 10, 2007 04:07 PM
wkdalpha
Feb 15, 2006 08:55 PM
CA6VTEC
Sep 14, 2004 05:57 PM
