Suspension & Brakes Theory, alignment, spring rates....
eg oem vs aftermarket rear lca length
Old Dec 20, 2013 | 09:47 PM
swizz977's Avatar
Default eg oem vs aftermarket rear lca length
hey if anyone has some eg oem rear lcas and some function 7 lcas can you do a side by side shot i want to see if there the same length for camber purposes
Old Dec 20, 2013 | 09:49 PM
swizz977's Avatar
Default Re: eg oem vs aftermarket rear lca length
or could the bushings affect camber too?
Old Dec 20, 2013 | 09:51 PM
Tyson's Avatar
They would absolutely be the same length.
What makes you think they would be different?
Old Dec 21, 2013 | 11:19 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
There is no difference between my f7's and OEM.
Old Dec 22, 2013 | 06:27 AM
spAdam's Avatar
Loved
Community Favorite
Specialty products used to make a shorter lower arm for camber correction if that is what you are looking for. No idea if they still make them.
You don't need to buy anything but some longer bolts for the upper arms and a stack of washers to fix the rear camber though. Hell, the Wicked Tuning upper arms are only $80 on ebay and are very decent.
Racer02gtstang
Suspension & Brakes
Mar 10, 2013 04:10 PM
thumper64
Suspension & Brakes
Nov 10, 2009 07:13 AM
EG2Driver
Suspension & Brakes
May 9, 2006 12:17 PM
turbotime
16
Jul 13, 2004 04:49 AM
