Clunking noise after koni/gc install ek
Old Dec 20, 2013 | 07:02 PM
bryan_lo's Avatar
Default Clunking noise after koni/gc install ek
I'm getting a clunking noise coming from the rear when I take turns. This is after koni/gc install on my 98hatch. Any ideas? First thing I thought were loose screws but all is tight.
Old Dec 20, 2013 | 07:18 PM
B_Swapped93's Avatar
Default Re: Clunking noise after koni/gc install ek
EJ.....anyways what hight ? tires/rims rubbing perhaps what wheel size hard to help not knowing this stuff.
Old Dec 20, 2013 | 07:24 PM
bryan_lo's Avatar
Rims are rota gt3 15x7 with falken 512 195/50/15. I'm not sure what height I'm at but the top of my tire is right on the fender I can squeeze my pinky in there. I don't think it's tires rubbing, because the noise sounds like metal to metal.
Old Dec 20, 2013 | 07:27 PM
there's the off chance it's the brake dust shield rubbing the rotor inspect just in case. 2nd guess is jack up the rear and spin each wheel looking closely for anything rubbing. 15x7 shouldn't do that you checked EVERY bolt was tight back there right ?
Old Dec 20, 2013 | 08:11 PM
bryan_lo's Avatar
Yes but I'll check again. I will also check the rotors and spin while it's jacked up. Weird thing is it happens when I turn. At first I thought the rear control arm was hitting the shock mount so I raised the car and still have the sound.
Old Dec 20, 2013 | 08:40 PM
Houston hb's Avatar
the rear is rubbing on the car, had that same issue when i had used 16x7 wheels with a low drop!
Old Dec 20, 2013 | 10:12 PM
NotARaCist's Avatar
I never narc'd on nobody!
Your exhaust could also be slapping your trailing arms. Best way to know for sure is to drive the rear end up on ramps, get down there, and see what's hitting what.
Old Dec 21, 2013 | 12:17 AM
93egSLEEPER's Avatar
Is the spring pre-loaded?
Old Dec 21, 2013 | 10:12 AM
bryan_lo's Avatar
What do you mean by the spring being pre-loaded? The shocks and coilover came in one assembly. I think I might have found the problem. The circled picture bellow is very close to the rim and the rim seems to have a weight for ballancing which I think is causing some rubbing when I turn. I'm going to take it back to discount tire to get that piece removed and rebalanced.
Old Dec 21, 2013 | 10:15 AM
looks like you found it would make sense also.
Old Dec 21, 2013 | 10:30 AM
bryan_lo's Avatar
is this a common issue? or my wheel offset are off? this was the suggested wheel by rota.
Old Dec 21, 2013 | 10:34 AM
what is your wheel offset ? 0 would do that or a low number, I have scrapes on mine with a +15 offset 15x8 no it's not stanced it's so I can run wide tires on my track car.
Old Dec 21, 2013 | 10:45 AM
bryan_lo's Avatar
offset is +40
Old Dec 21, 2013 | 11:04 AM
shouldn't be clearly it is I had my weights put on the inside of the wheel still got scraped by the caliper(wilwood 4 piston) tho lol. take it and ask them to move it should work for you.
Old Dec 21, 2013 | 01:12 PM
bryan_lo's Avatar
just came back from DT, removed that piece and reinstalled tape weight and all is fixed
kaotikvizion
May 8, 2009 09:46 PM
turbotime
May 6, 2007 03:21 PM
SpeedMachine
Oct 27, 2004 08:06 PM
hecklervtec
Apr 8, 2004 09:41 AM
Trellis
Jul 24, 2003 06:58 AM
