EF Civic Hatch - Trasmission will not shift
Old Dec 19, 2013 | 07:41 PM
cycon82's Avatar
Default EF Civic Hatch - Trasmission will not shift
91 Civic DX Hatch unmolested.
D15 engine
5-speed
Chain of events as follows:
-Picked up a 91 Hatch
-Replaced the CV shafts
-Car was vibrating pretty bad
-looked into replacing motor mounts
-discovered that the front motor mount was MIA
-Discovered the brand new driver side CV boot was wadded up and the CV was broken.
-installed new MM
-Installed new CV
-Test drive went famously!
-Shifted through all gears(including reverse) No issues
-come to complete stop...will not shift into any gear.
Any gear it feels like neutral.
car can be shifted without the clutch being pressed down
no debris in the clutch cover
At a bit of a loss........
Help me out guys!
Old Dec 19, 2013 | 09:32 PM
jonGSR's Avatar
Default Re: EF Civic Hatch - Trasmission will not shift
Clutch cable not stripped? Have you checked it?
Old Dec 20, 2013 | 04:13 AM
cycon82's Avatar
Clutch cable looks to be working fine. I can get a light gear grinding noise,like it is not quite in gear, from reverse only and the pressing the clutch in stops it.
Old Dec 21, 2013 | 03:12 PM
cycon82's Avatar
Anybody?
I will be pulling the transmission out tomorrow.
I have been told the possibility of broken throwout bearing, snapped output shaft, or snapped shift rod
Old Dec 22, 2013 | 06:59 AM
jlicrx's Avatar
make sure that both axles are completely into the transmission
Old Dec 22, 2013 | 11:06 AM
Riceburner247's Avatar
1. Check axles
2. Check shifter linkage
3. Check clutch cable again
4. Pull transmission
I've had issues with aftermarket axles feeling like they clicked into the trans when they really didn't. Put front end on jack stands. Take bolt out of the lower control arm at the chassis end, don't mess with the ball joint end. Take bolts out holding the tie rod to LCA. I usually pull the spindle away from the car ever so slightly, then shove it back towards the car with the force of a thousand suns. If it doesn't click in, check the snap ring on the end of the axle and try again.
betsy96
Jul 1, 2013 03:18 AM
ThaEfSwap
Nov 29, 2011 06:37 PM
dirty sanchez82
21
Aug 8, 2007 09:01 PM
94eg5squadMD
Jul 2, 2007 07:54 AM
lapulapu
10
Sep 8, 2006 03:03 PM
