Need help - Fog Lights for 2003 Civic LX
I know, another fog light question
I've been looking at this problem for a few days now and can't get further, so if someone can help me narrow it down, it would be appreciated. I currently have ALMOST everything connected. The part i'm stuck on, is the power wire, where do I tap into? First off its a Spec-d Tuning fog light kit for 2001-2003 2/4door civics. One of the wires has a Four pin connecter, with only one thin red wire, the other one is a wide 1 pin connector, connected to a fuse box, its a thicker red wire. What do I do with these two red wires? What do I connect/tap it into? I've tried searching many other forums and videos, and they're all different fuse boxes than mine and/or different years.
I'm also a visual learner so pictures could help! THANK YOU!!!
I've been looking at this problem for a few days now and can't get further, so if someone can help me narrow it down, it would be appreciated. I currently have ALMOST everything connected. The part i'm stuck on, is the power wire, where do I tap into? First off its a Spec-d Tuning fog light kit for 2001-2003 2/4door civics. One of the wires has a Four pin connecter, with only one thin red wire, the other one is a wide 1 pin connector, connected to a fuse box, its a thicker red wire. What do I do with these two red wires? What do I connect/tap it into? I've tried searching many other forums and videos, and they're all different fuse boxes than mine and/or different years. I'm also a visual learner so pictures could help! THANK YOU!!!
Will it be too much trouble to uninstall the wiring harness, lay it out on the ground and take a picture of it? Or maybe draw up a diagram in MS Paint?
I'm guessing the thin red wire will connect to the wiring in the engine bay through the firewall. Not sure about the thick one, perhaps it goes to another slot in the fuse box.
*edit*
found this thread, hope it helps.
http://www.6thgenaccord.com/forums/s...&postcount=400
*edit*
Maybe the instructions for the OEM fogs will help: http://www.handa-accessories.com/civic/civ03fogs.pdf
Black Diamond
Jun 4, 2010 04:14 AM
