PLEASE HELP! 91 Civic Si Door Checker Repair ................................ Picture
Old Dec 18, 2013 | 12:39 PM
xpimpindistressx's Avatar
Default PLEASE HELP! 91 Civic Si Door Checker Repair ................................ Picture
Hey Guys,
I need help from ones who experience this same problem before or know of a permanent solution.
As you can see in the picture, my driver door checker is f***ed. Original owner try welding the rear end part to be stationary but the weld broke and just looks like crap.
How do i fix this issue? I want to reframe from further welding and making it even uglier.
I know theres two parts to this door checker piece (one that connects to door, one that looks connected behind the front fender)
What are my options?
Thanks
Old Dec 18, 2013 | 01:35 PM
4drEF's Avatar
Keyboard Humorist
Default Re: PLEASE HELP! 91 Civic Si Door Checker Repair ................................ Pic
2 ways I know of, but both require welding and both require you to strip all the wires out from inside the kick panel.
1) You can cut the original one out and weld in a newer+reinforced one in from a donor car.
2) Attempt to weld it from the backside.
What you can't do is unbolt and replace the hinge unit from the car. it's welded in from the backside from the factory.
Old Dec 18, 2013 | 01:48 PM
geez! thats a bummer. honda can make an awesome vtec motor but can't get a simple door right.
thanks for the 411 4drEF
Old Dec 18, 2013 | 06:16 PM
bheinen74's Avatar
all this is is a simple anchor point with one hole thru it for the pin to go thru. Should be able to just grind out the old failing one, and refabricate a new system, with a new hole. then just spot weld the entire thing overtop the old section that is good still.
then when all is said and done, every few oil changes, lubricate the slide mechanism.
Everyone who owns EF should be lubricating the slide hinge regularly to prevent the sticking which in turns causes this.
Old Dec 18, 2013 | 07:45 PM
SIRX's Avatar
any quality body shop will be able to fix that in 2 hours it should cost you less that 150. take it to a professional and have it fixed right.
GPC91
Dec 7, 2012 06:00 PM
89hatcher
Mar 10, 2009 04:47 PM
LazJDM
Apr 21, 2006 04:30 PM
silvernick711
Sep 24, 2004 08:16 AM
tominos
Audio / Security / Video
Feb 24, 2004 07:13 PM
