which thottle cable/bracket/pulley to use? D16y7
Old Dec 16, 2013 | 03:42 PM
parki59's Avatar
Default which thottle cable/bracket/pulley to use? D16y7
Hello,
Car is a 97 Civic w/ d16y7, skunk2 IM and GSR TB. My factory throttle cable had to be jerry rigged and a butchered cable bracket had to be made to make the car driveable.
Does anyone know if there is a specific cable/bracket to use for this setup, nothing seems to line up or fit nice. I did replace the pulley wheels from my stock TB to the GSR(with modifications) but now the pulley is starting to fray the cable.
I think I remember reading/hearing something about an automatic y8 bracket/cable/pulley working but I cannot recall.
Any input would help...
I have tried using trusty google but there are too many specifics.
Thanks,
Old Dec 16, 2013 | 03:54 PM
B_Swapped93's Avatar
Default Re: which thottle cable/bracket/pulley to use? D16y7
ITR able and bracket. I hope you have a swapped b-series in there. and didn't just wate money on a d16y7 N/A.
Old Dec 16, 2013 | 04:01 PM
parki59's Avatar
I have never heard of anyone running an ITR cable and bracket on their D series....for a B series swap I know you have to run at least the cable.
If that is the case, what about a B18 cable?
Old Dec 16, 2013 | 04:15 PM
Well a d16y8 cable and bracket will work also, I was just assuming this was a swapped civic.
Old Dec 17, 2013 | 03:42 AM
apexi_rsx's Avatar
if it has a sk2 manifold instead of the y7 use a y8 throttle bracket.. any throttle cable will work they are adjustable..
mouab18c1
20
Jul 9, 2013 11:36 PM
TypeRfit
Feb 26, 2012 06:54 PM
lilo_goki
May 1, 2009 03:01 AM
mister_ej2
Mar 27, 2008 08:17 PM
dc4drewH
Apr 25, 2005 07:06 PM
