OBDI scanner or OBDII to OBDI adapter?
Old Dec 16, 2013 | 10:36 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default OBDI scanner or OBDII to OBDI adapter?
Hello, both of my civics are 5th gen OBDI cars. I can get a really nice bluetooth OBDII scanner and Torque for Android for around 40 bucks USD. I was wondering if anyone knew off hand if just getting an OBDII to OBDI adapter would work or do I need to get a specific OBDI Honda scanner?
I know you can get the codes by counting the blinks and don't have to have a scanner, but I'm thinking I should get an OBDII scanner just to have on hand anyway and thought it might be nice to utilize it on my OBDI cars if that is even possible.
Old Dec 16, 2013 | 10:41 AM
kyden's Avatar
Default Re: OBDI scanner or OBDII to OBDI adapter?
it won't work.
Old Dec 16, 2013 | 11:43 AM
B_Swapped93's Avatar
nope, you're stuck with the old paperclip in the connector trick. also just get an actual scanner not a gimmicky device like that.
Old Dec 16, 2013 | 01:05 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I was afraid of that. Looks like a Honda Interface Module is needed with the HDS software.
@B_Swapped93 The one I would get is pretty good and not some China knock off. Guy I work with has it and pointed me at the one he got. It's made in USA and works really well on OBDII and with Torque he can do resets, log with GPS and monitor and many other things beyond just pulling codes. It's a pretty nice setup over all and easy to use.
I was hoping it would be backwards compatable for the Automatic EG civic I have. But I'm guessing I'd need a whole nother interface for the Auto Tranny.
Pros and cons to a OBDI cars.
Thanks for the replies.
Old Dec 16, 2013 | 02:06 PM
andyz's Avatar
Check my adapter build.
https://github.com/andyzsmith/HonOBDapt
Old Dec 16, 2013 | 02:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by andyz
Looks pretty kewl, If you get this completed, I'm sure there are a few of us that would be interested.
Old Dec 16, 2013 | 03:34 PM
andyz's Avatar
it works, but it don't look that pretty , yeah.
The sales market for such a thing is so very small, it would really be just a group hobby thing to maybe get a couple dozen fabricated and tested and put in a little prettier box. The means to do such a thing is all there, it is all released under open-source, schematics, code, description of how its supposed to work, so if somebody wanted to they could...
Old Dec 16, 2013 | 07:08 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I think the hardware side of things would be pretty easy for most of us to follow and build, the C++ software side on the other hand.....
Maybe a compiled version and a how to on the hardware build with parts list?
I agree the market for it isn't really there... OBDI is a dying beast, not too many left on the roads anymore, and this is Honda specific, probably one of the larger selections left for OBDI.
Old Dec 17, 2013 | 08:40 AM
andyz's Avatar
well, it's all the doc/HonOBDapt.doc. the first page or so goes over the overall scheme and the parts. Schem.JPG is pretty much all there is to say about the hardware really. You can wire it up with anything handy. I guess one thing that is not obvious to the unfamiliar is that for the Arduino setup, you just have to get the Arduino plugged into your USB port, and then use the regular Arduino environment to open the source file and compile and upload it. Its a no brainer, just need the Arduino IDE.
Old Dec 19, 2013 | 07:38 AM
94EG8's Avatar
Seagull Management
Canadian Tire had an OBD2 code reader with a bunch of OBD1 adapters on sale a while back, but I'm not sure if it would do Honda.
Old Dec 19, 2013 | 11:14 AM
Matt_EH3's Avatar
This is rather interesting. I will look this up. I want to figure out if the Honda diagnostics port provides the other data that OBD-II also provides (such as engine RPM, throttle position, etc.). Reason why I find this interesting is that there are more and more data logging products nowadays that use the OBD-II port. Perhaps what you have done can be used as an interface for us racers with older cars.
Old Dec 19, 2013 | 12:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I kinda of doubtful it works with Honda too. Kinda of interesting but I think that was the issue with OBDI is every one did their own thing.
Old Dec 20, 2013 | 07:49 AM
andyz's Avatar
Consider the OBD II standard. Actually there are five protocols allowed by the standard. Each protocol has to be tested for by the universal scanner and used if it responds. Guess what the five protocols are? Variations on the protocols used by dominant manufacturers at the time of the creation of the 'standard'.
Old Jan 19, 2014 | 03:21 AM
Civic1.4is99's Avatar
I have a 1999 honda civic 5dr hatchback 1.4is UK spec. where can i find the data port for engine diagnostics? please someone help
Old Jan 19, 2014 | 04:45 AM
HondaPartsHero's Avatar
Technical Hero
Do you have a check engine light? The 1.4 UK models don't have the same port as US. Follow this guide for yours:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Jan 19, 2014 | 05:50 AM
Former User's Avatar
What data does the Honda OBD1 ECU provide?
MP1975
Dec 30, 2015 11:28 PM
YWSEAN
Jan 31, 2013 06:19 PM
MeleeFaction
Welding / Fabrication
Jul 13, 2010 02:01 PM
dallasaccord
Sep 17, 2002 01:36 PM
crxzc
Jun 22, 2002 12:41 PM
