Would you run this ported GSR head?
Old Dec 16, 2013 | 03:26 AM
SwappedTURBOegg's Avatar
Default Would you run this ported GSR head?
I acquired this head threw a trade figured i would keep it as a spare,im currently running a stock port head and shooting for a little over 800whp next season.
noticed this head had been ported and i wonder if the port job,[who knows who ported it]. would be better or worse for my setup im on a pretty small cam still. heres some pics.
when tacking pics i noticed this,whats up with the guide on the right?
exahust seems like a very light job
Old Dec 16, 2013 | 05:23 AM
jimbo slice's Avatar
Default Re: Would you run this ported GSR head?
Easiest way to know for sure is to have the head flow tested to see if the cylinders are balanced well. I don't like basing a heads performance off CFM numbers only. There is far more to how a head works than just that figure.
I can't say for certain what's going on with that guide. I would have the head shop who's checking the flow do a thorough assessment on the head while they have it.
Old Dec 16, 2013 | 05:03 PM
tepid1's Avatar
Looks like the guide pinched the valve stem and went for a ride.
Old Dec 16, 2013 | 10:06 PM
H23a4thgenbb2's Avatar
I will tell you your best bet is to sale the ported head
And send your stock head to get a good port and polish
From a quality machine shop so you know its done properly. Lol or just get a h22.
H22>Gsr
Old Dec 17, 2013 | 08:47 PM
Ill make 800 on a stock port before i send it out. can anyone tell by just looking if this looks runnable? has anyone LOST power in a turbo setup with a shitty ported head?
last season i was in the mid 40s psi trying to keep boost the same and bring power up.
Old Dec 17, 2013 | 09:32 PM
bauergold's Avatar
Why not just run the stock port head? Probably will make more power than the alternative.
Old Dec 17, 2013 | 09:39 PM
I probably will since i had a minor cam change since last season.the car is apart already,just trying to learn something.
Old Dec 17, 2013 | 09:46 PM
raverx3m's Avatar
this doesnt look like it was ported
just someone playin with a dremel tool wherever they can reach
the area above valve seat( where the casting is cut by machine and valves are installed is not smooth. if i understand correctly thats the first area that is worked on when head is ported. even stock itr head has that wrorked on.
bowl blending its called?
Old Dec 17, 2013 | 10:03 PM
Yes the blows are stock, like the valves never came out. i was going to try messing with the bowls. I compared it to my stock head sitting next to it. its been worked over quite a bit actually..
Old Dec 17, 2013 | 10:19 PM
raverx3m's Avatar
well like many porting articles say the area thas been worked on thsi head doesnt really have any effect on flow.
Old Dec 18, 2013 | 06:52 AM
scmil95eg's Avatar
My vote: man up & run it Chris.
You know you're going to change it 6 months from now anyway.
Old Dec 18, 2013 | 08:37 AM
4piston's Avatar
That's not ported. That's fluff and buff, there is no material gone that would improve anything. Either way, it needs freshened up by a machine shop before it goes on any engine.
EH-3
Jun 19, 2006 09:36 AM
iperez
Jan 22, 2004 03:00 PM
