Suspension & Brakes Theory, alignment, spring rates....
Integra 93 GSR Rear front cross member on 90 EF ???
Old Dec 15, 2013 | 09:07 PM
Frankacura's Avatar
Default Integra 93 GSR Rear front cross member on 90 EF ???
Hi
I have bad boushing on my 90 EF suspension so working on it as the motor is not in.
I do have all the front end from Integra GSR 93 DB2 model as DA9
The only differance in the 2 cross members is where the table attachment is,
On the Civic cross member the hole to tie the lower table is 1/2 inch lower
They are 2 cross member with power steering
The 2 lower Table from the 2 cars are 15 inches long.
The Integra Knukkle and bering should fit right there.
Top Table is same size and bolt on the same place.
Struth-rods bars are 1 inch shorter on the EF, so i will need to use them on the stock EF front front cross member
- I do have adj suspenssion Coils springs in case...
- I dont want to lower the car to much, 1 inch
- I want to use the Honda stock integra shock
90 Civic EF 4 Doors LX was 2300 pounds
It will end up at 2500 with the B motor, CRV transmission and the equipement.
So my questions are...
Can i Swap the Integra complete suspenssion, Front rear cross member, table and brake on my 90 civic EF ??
And will i have a descent Camber ??
Is car will raise or get lower suspenssion ?
Or if it will fit but on EF stock coils springs ?? ( Cuz stock EF coils should get a bit lower with the add of weight)
Please if you do know about it, help !
Frankacura's Avatar
Default Re: Integra 93 GSR Rear front cross member on 90 EF ???
Old Dec 15, 2013 | 09:12 PM
Frankacura's Avatar
Old Dec 15, 2013 | 09:13 PM
Frankacura's Avatar
Old Dec 15, 2013 | 09:14 PM
Frankacura's Avatar
Frankacura
Dec 17, 2013 12:52 PM
OGKoopa.
Suspension & Brakes
Dec 29, 2012 12:54 PM
949
Oct 17, 2008 12:27 AM
TurboGSX
Apr 10, 2007 12:32 PM
