Rate My GSX 1-10(1=low, 10=high)
Engine Specs
Fully built 4G63 with race prepped crank, crower rods, and JE 9:1 pistons
Balance shafts have been eliminated
Turbo Specialties T3/ T04e Hybrid Ball Bearing Turbo and O2 Eliminator
TIAL 40mm External Wastegate
South Florida Performance Tubular Exhaust Manifold-Jet hot coated
Ported 1st Gen Head with 5 angle valve job
Custom Crower cams
Crower Titanium Retainers
Crower Valve springs
Crower 1mm oversized stainless valves
HKS head gasket
ARP Head Studs
1st Gen Intake Manifold and 60 mm Throttlebody-Jet Hot Coated
Dejon Tools Intake Manifold Heat Spacer
Unorthodox Racing Polished Cam Gears-Polished
Unorthadox Racing Pulleys-polished
Greddy Big Front Mount Intercooler-Polished
Greddy Type-S Blowoff Valve-Polished
Custom Chrome Intercooler Piping
3 Inch Stainless steel Air Intake with K&N Filter-Polished
RSR Stainless Steel 3’ Downpipe
RSR Stainless Steel 3’ Cat Back
HKS VPS and Apexi S-AFC(Switching To AEM EMS Stand Alone when avaliable)
Hollaman Boost Controller(Switching AEM EMS Boost Controller when avaliable)
660cc Injectors
Warlboro Fuel Pump
Nitrous Express Nitrous Kit- 100 HP (2 Polished bottles)
Injen Polished Overflow Tank
Fluidyne Radiator
Polished Aluminum Radiator pipe
Flex-A-Lite Fans with adjustable thermostat
Magnacore 8.5mm Wires
ACT 2100LB Clutch
Carbon Fiber Spark Plug Cover
Injen Polished Fuse Box Cover
Hose Techniques Hose Kit
Greddy Oil Catch Can
Polished oil cap
This car will make 400 to 500 hp depending on how much boost i want to run. Thats without the nitrous.
I like the whole thing except for the wing and decals. Most people look at cars and want a sleeper, so they will knock you for the body kit and all. I personally like it. As long as you don't race with those wheels, they are good. Rims aren't meant for looks not function unless your at the track. I give it a 9, wing and decals drop it a point. But very clean car. Good job.
[Modified by autoEXturbo, 9:51 AM 10/28/2002]
Bad *** DSM bro. Good to see another DSMer on here. Check out my GST here: https://honda-tech.com/zerothread?id=316787
god wouldnt that be the ultimate sleeper if he just put some black wheels on it and got rid of the wing and decals...ooooo.
i bet its quick as hell.
Looks good to me, I give it an 8.
If you must have a wing, I like the 1st one better then the one on the last pic.
I live in Rhode Island & I belong to another online club www.clubsi.com & we do meets once a month ( in warm weather of course ) so if you ever what to hang out, let me know.
Keep up the good work,
Very clean engine by the way...
pretty nice man..you love you polished parts hey
..what the hell does that thing run..i mean you slap a filter and boost controller on them you hit like low 14's easy..
How can you guys honestly call this car a failure? The engine is fully built, he has all the supporting mods to run like 28psi and could easily run 11's. So just because it has some ''different'' side skirts, a huge rear wing and stickers you call it a failure??
i know it's your opinions and all but what are you basing them on????
I give two ***** about a nasty riced out 11 second car
rather see a real car.
His car isn't even 'riced out' that much... just remove the wing, decals and skirts and it would be clean as hell.
