Problems with the stuff in my trunk getting wet...
Old Dec 14, 2013 | 08:14 PM
honda.girl.1991's Avatar
Default Problems with the stuff in my trunk getting wet...
I have a 1991 Honda Accord EX, and all the things in my trunk keep getting wet every time it rains. I just had a spoiler put on my car but before I did that I was still having this problem. What could it be? I have sealed up my tail lights with clear silicone. Help me please.
Old Dec 14, 2013 | 08:51 PM
lazlong's Avatar
Default Re: Problems with the stuff in my trunk getting wet...
Inspect the trunk gasket. If that doesn't work, get in the trunk with a flashlight while your friend hoses down the outside of the trunk.
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
^^^ In addition to that check your sunroof hoses, and see if they aren't clogged up. THere are four; one on each corner.
Old Dec 16, 2013 | 08:45 AM
mrj_accord's Avatar
if u have the telescopic antenna, check this also
Old Dec 16, 2013 | 09:27 AM
GhostAccord's Avatar
also check for holes in your inner wheelwells. I had the same issue and found that I had a small rust hole up above my rear wheel in the fender.
There are two pieces of sheet metal that come together in the wheel well. The outer fender and the inner wheel well. The inner wheel well is basically the trunk panel as well. A lot of times there will be dirt and debris that sits up on top of the wheel well trim that causes the inner wheel well to rust an a hole to form. You then may also start to see your paint bubbling around the wheel well. This is rust that is coming from behind the paint. 9 times out of 10 it is a hole through to the wheel well.
Then when you drive in the rain/wet roads is sprays water up into the trunk through the hole in the inner fender.
There was a little rust on the outside of the wheel well.
and here is how bad it was in behind the wheel well trim
Those holes lead into the trunk and where there is no real divide between the trunk and the rear seat. Some water even got into that area as well.
Hopefully yours is something simple like a seal or the sunroof drains.
Old Dec 16, 2013 | 04:22 PM
Community Builder
i'm having a leak issue in my trunk also. The leak comes from the driver rear, and I think what Ghost posted could be my problem.
Demigod2019
Jun 9, 2019 10:45 AM
Mike052
10
Jan 13, 2012 04:53 AM
dafranchise69
Nov 28, 2005 05:18 AM
LankorDie
Jun 8, 2004 02:15 PM
Dawsonb17a
Jun 25, 2001 08:11 AM
