whinding sound
Old Dec 13, 2013 | 07:36 PM
Marco1988's Avatar
Default whinding sound
Hello I need help.
I have a 88 crx with a b18a1 with a sir trans.
The issue is that there is a whinding sound..once I speed up..
The car turns on fine it shifts fine the clutch feels good but once I get to 3200 rpm the sound comes in only while I'm driving not when.I'm.parcked plz if anyone knows plz help..
Old Dec 15, 2013 | 09:31 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: whinding sound
Sound like improperly aligned trans gears
I may be wrong
95
Old Dec 16, 2013 | 12:17 AM
Marco1988's Avatar
What do you suggest just get another one..
Old Dec 16, 2013 | 02:37 AM
Freemananana's Avatar
I want more information than a whinning sound. Is it at 3200 in every gear? Is it 3200 rpm or a set speed? It could be something grinding, that's for sure. When was the last time you did any fluid changes? It could be outside of the trans though. The motor is also a giant moving piece. If you have a spare trans at your disposal, try swapping it. If you want to actually trouble shoot this, you need more information.
Old Dec 16, 2013 | 08:31 AM
Marco1988's Avatar
The car turns on fine also shifts good gears don't pop out once I start driving if I'm goin slow no sound but once I speed up there that sound also if I ingage the clutch still makes that sound..the fluid on the transmission is new I just changed it with the Acura dealers transmission fluid also I change my axles and throw out bearing the clutch and the clutch had alittle rust is that I gong.kind.of wet sitting.on my.garage but it was new..the sound is coming from the passenger side..it started once I he mechanic installed the new tranny and right after he was don't I took it for a.test drive one I made a turn the passanger ball joint gave it he.put the wrong nut on the stud he changed it but still the sound was there..
Old Dec 16, 2013 | 08:34 AM
i cant evn bginto read this kind of stuff... it cant be 2 hard to type with periods and stuff can it... gosh the people on here cant type.like at all this makes my brain hurt cuz i wanna try n give you some help but you just make it so hard with these run on sentences and stuff and you put periods with no spaces and no capitalz and stuff and it just makes it so hard to read and...
Seriously. I would appreciate a retype.
Old Dec 16, 2013 | 08:54 AM
Marco1988's Avatar
Sorry its hard to do this on a cellphone..
I had a transmission swap a few weeks a go. I installed a sir transmission. I had it installed by a mechanic. The day he installed it the passager side ball join gave out becouse he use the wrong nut. But the transmission has New oil,does not pop out in gears,does not grind,shifts perfect.once I start the car the sound is not there, I can drive it for a bit and be ok but once I reach a certain speed the whinding sound comes on. I really don't know what it is. I changed the axels, throw out bearing, also changed the transmission fluid 2x's
Old Dec 16, 2013 | 09:01 AM
What exactly is the passenger side ball joint? I can only imagine something giving out means something broke. There are several ball joints to my knowledge. Which one? The upper, lower, tie rod, ect? Are you sure the transmission didn't have issues prior to install? It could be a 'bad' transmission.
Old Dec 16, 2013 | 09:44 AM
Marco1988's Avatar
The lower ball goint. After that happen the car started making that sound..ill try to make a video and post it
Old Dec 16, 2013 | 10:59 AM
Did he actually replace the lower ball joint? Maybe he damaged something else.
Old Dec 16, 2013 | 12:12 PM
Marco1988's Avatar
Yes it was replace
Old Dec 16, 2013 | 12:15 PM
Marco1988's Avatar
Old Dec 16, 2013 | 12:22 PM
Marco1988's Avatar
Old Dec 17, 2013 | 09:11 PM
prodjay10's Avatar
Your video is either private or doesn't exist. wth.
Old Dec 17, 2013 | 09:32 PM
kennyvilla's Avatar
I installed a new alternator on my d15 and ever sence then its been making a whining noise. I used the old belt but it makes like a supercharger whine. It makes its when im above 3k
Old Dec 18, 2013 | 03:54 AM
F22Who's Avatar
Idontunderstandwhatyouaretalkingabout,sincewhendoe stheenglishlanguageusespaces? hahaha Freemananana for Pres.
Old Dec 18, 2013 | 03:59 AM
F22Who's Avatar
Might want to get a new belt IMO ( only a few dollars ), would hate to hear that it snaps and your left with a dead battery.
Have you had a fiend or family member listen to your car from the outside as you drive by? Alot of times you can at least narrow down what area the sound is originating from that way? Just food for thought.
vietdragontekx
Dec 27, 2005 11:50 AM
lliew
12
Jul 30, 2002 08:27 AM
vpforeva
Oct 30, 2001 02:05 PM
