How to Repair your GSR/ITR/B16/H22 3rd Gear
Most people have no idea that the Mainshaft 3rd Gear in the GSR/ITR/B16 Hydro/ and H22 comes apart in 3 pieces. Some will tell you that buying a new 3rd gear is expensive and most of the time requires you to buy a whole sleeve set along with it. We are now proud to offer a cost effective solution to repairing your 3rd gear synchromesh teeth.
I will advise that this should be done by a professional with proper safety equipment. Use of a hydraulic press is dangerous!
Here are a few steps to help understand how the gear comes apart
You will need a suitable press to do this with ease
Here is a close-up view
Here are the pressing points
When pressing on the new piece it is important to line the tabs on the center washer
Make sure to align the center teeth before pressing. If you spin the top half slightly...you will feel the teeth line up. Press down until they are mated and you are done! Enjoy!
Thanks James
It's always nice to see cost effective solutions come on the scene. The 3rd gear grind is a common problem for B-series owners and unfortunately it can be expensive to fix.
Here is a link:
http://shop.synchrotech-transmission...-H22-SG120.htm
I don't want to post pricing as this is not a sales forum
Do you know what parts are needed? Typically it is the 5th gear and 5th gear sleeve that need replacement. Please contact me when you know what it is that is needed. I will be happy to help you out.
I just ordered a mfactory diff and bseries carbon master kit from synchotech all I am needing is the speedfactory sch and my trans is done!
We do sponsor this forum btw...
A moderator has approved this thread. But, please rest assured that your grievances will be addressed in a timely fashion.
James has talked to me about this. Synchrotech has always been great about not turning their threads in tech sections into advertising threads. They're generally strictly tech related, and they normally have some very nice tech pictures.
