Transmission & Drivetrain Gearboxes, Differentials, Clutches
Manual Transmission Problems
Old Dec 13, 2013 | 02:49 AM
Loy's Avatar
Loy
Default Manual Transmission Problems
I have a 96 Accord with a 2.2L vtec and 5 speed manual transmission. The problem I'm having is when I left off the clutch to drive I hear something that sounds like of you was to rub to pieces of sandpaper together and the car does not seem to be accelerating like it did when I first got it. The guy I bought it from said he had just out a new clutch in it but I'm thinking he either didn't do it right or something else maybe going on and I think that's it's the transmission since the thatsbrhe only time I hear it is when I'm driving and the engine and transmission are both under load. Any suggestions on what this coyld be please help. Thanks.
Old Dec 13, 2013 | 02:52 AM
Fliptard's Avatar
Default Re: Manual Transmission Problems
re-bleed the clutch pedal, and look on the inside of the car up under the dash at the clutch master cylinder and see if it's leaking inside the car.
He may have replaced the clutch, but used a cheap-o one and its junk.
Old Dec 13, 2013 | 05:26 AM
Loy's Avatar
Loy
I'll check that out when I get back. On the other hand I will mention that it seems to shift fine however the clutch does seem to be a little jerky. Almost like it ingauges and disingauges very quickly. Reason I say this is because you can actually feel a little jerk when you press in the clutch and you have to let off the clutch very slow because it ingauges very quickly. Would a vacuum leak cause an engine to have almost no acceleration power to it when it's under a load but seem to run just fine if it's in neutral?
Mikej959
Nov 21, 2015 10:37 AM
adknate
Mar 18, 2015 07:44 AM
asselinma
Apr 17, 2012 08:31 PM
tercelrcr
Oct 29, 2010 04:30 AM
g22aOnBoost343
Feb 12, 2010 07:03 PM
