1991 Honda Accord Lx idles erratically and Lurches when accelerating
Old Dec 12, 2013 | 01:59 PM
Chin Zimbabwe's Avatar
Icon6 1991 Honda Accord Lx idles erratically and Lurches when accelerating
Hi guys. I'm quite excited to be a member here and to have my Honda, its a little 91 Accord with 190k miles on it. I don't drive it much but would love to work on it myself. The check engine light came on after some time the car had displayed a burnt tail light which I haven't fixed. Now last weekend it snowed and I went out to help a friend who was stuck out on the highway. I used my car to push hers up a steep slope for about five minutes of high revving after which I began smelling something like burning inside my car. I stil smell it when I revv. Now when I start my car, it idles at first at about 1500 rpm and then falls as the car warms up.
Again, I noticed that when driving, and when I shift into the 2nd and 3rd gear, the car lurches when I press the accelerator, for reasons unknown to me. When I revv also I notice that the engine shakes its like it first breathes then revs making it look like its revving twice in quick successions.
I had it serviced in August but it was for State inspection and the guys did what needed to be done. As for the check engine light, I used a money clip to check and the car blinked 9 times. Does anyone know what that means?
I appreciate your help guys, sorry for the lengthy narration!
Last edited by Chin Zimbabwe; Dec 12, 2013 at 01:59 PM. Reason: change of diction.
Old Dec 14, 2013 | 01:32 AM
holmesnmanny's Avatar
Default Re: 1991 Honda Accord Lx idles erratically and Lurches when accelerating
Your car is going to idle higher from a cold start until the car warms up, which it will then idle regular. Completely normal operation.
For the check engine code, that sensor is inside the distributor. If you got a junkyard nearby, you can try to pull another distributor from any 90-91 accord and see if that fixes it.
You will need to redo your ignition timing by using a timing gun afterwards. There are howto's on how to set your ignition timing on youtube.
Old Dec 14, 2013 | 06:32 AM
ej7attack's Avatar
I hope helping your friend was worth it!
is the car manual or automatic?
Old Dec 16, 2013 | 06:03 AM
I'm much obliged for your responses. I watched the video to redo the ignition timing and I called a few junkyards for the distributor am going to get it from one of them.
And the car is manual.
Thanks a lot for your help guys, will let you know soon as I finish what's up!
Zarkul
Mar 21, 2018 04:35 PM
powermac867
Oct 1, 2015 11:23 AM
Dizzyman
Apr 11, 2013 08:10 AM
Brum_RU
Jun 4, 2012 06:27 PM
