High quality turbo parts and more
I've got some parts off my old turbo setup as well as other parts I no longer need.
-SLS top mount manifold purchased off of dseries.org, it did crack at the wastegate but it is getting tig welded this week. T3 flange, 44mm vband wastegate. SOLD
-Tial MVR 44mm wastegate. Purchased off here as well, silver, all fittings, perfect condition. Has two springs inside equating to 12 psi. Can in clude dump tube if you want. SOLD
-Drop Engineering 96-00 Civic stainless steel engine mounts. 75A, bushing were repleaced at the end of last year, in great shape. SOLD
-96-98 Civic mud flaps, fronts are worn down from when I used to have my car dumped, otherwise in great shape. $50 shipped
-D series od school blue AEM car gear, missing one of the three bolts. $20 shipped
-Exedy twin disc for 91-05 NSX, I would recommend replacing the plates/discs. $300 shipped
-Blox fixed endlinks, barely used. $30 shipped
-OEM d brackets to run a sway bar on an a 96-00 Civic subframe without purchasing a subframe brace. $25 shipped
-GSR cluster out of a 1997 I parted out, 2xxk miles, fully functional, has a few backlight bulbs out though. $40 shipped
-I also have a complete auto y8 longblock I recently picked up. If you need any random pieces pm me, I am keeping the head and bottom end, but things such as IM and throttle body or other brackets I do not need.
I'll add more as I think/find things. Thanks.
Text 414-418-5110 for pictures
OLD spring colors / new spring color in mvr 44 wg
Brown + Maroon /Green + Blue =8.70 psi 0.6 bar
Grey + Gold /Black + Red 10.15 psi =0.7 bar
Grey + Maroon /Black + Blue =11.60 psi 0.8 bar
Brown + Gold + Grey /Green + Red + Black =13.05 psi 0.9 bar
CAn u check what color springs u got? Interested in the MVR 44mm
WAUKEENEM1
Apr 11, 2014 06:17 PM
ccfab
Jun 1, 2006 04:48 PM
teamrocket si
Feb 11, 2004 09:30 AM
