Some of you guys might get a kick out of this....
Then they rotate them wrong. Front wheels to back, back to front should keep the rim and tread facing its intended direction. Ive never had a set of tires that could be rotated in an X pattern.
Or am I missing something ?
Not calling you out, but I was told it was due to steering for the front wheels and power to the rear wheels. That theory doesn't apply to FWD cars. I would still reccomend the X pattern. But that would require the tires being swapped if you have tires that are meant to face only one way.
TBH ive never rotated tires on any of my older cars because i just didnt care. But on my CRZ i usually go Front LEFT to back RIGHT, Front Right to Back Left , Back Left to Front Right.
my understanding was that the Back RIGHT is the least "worn" tire because its at the area with the least weight (passenger side , rear). The Front left is the most worn because of engine weight and Driver weight (extra 150-250 lbs depending).
So you want to swap those two when you rotate right?
My tires always seem to wear evenly enough side to side, now that I think of it, they have pretty much worn evenly front to back as well. I drive my cars pretty aggressively though, so i use the tread more evenly than most. I either switch front to back(or vice versa) or just get a completely new set of 4 tires.
BTW, that is one CLEAN CRX!!
Yes, I believe so since the tire would be facing the opposite way if you kept it on the same rim. My tires on my car only run one way, so I just swap front and rear.
The X pattern should be used when tire tread is non directional. If tread is directional they should be front to back and back to front, and also if the X pattern will make your wheel look dumb.....
If the exhaust tips have not been touched, This CRX has a stock factory axleback which
appears to be in mint condition. It must has very low milage. Such a beauty. Take more pics will ya?
So, that might or might not prove anything. At least they use OEM parts if so.
OhShift!
Feb 2, 2012 10:18 PM
