Skunk2 Pro 2 Cams..This look right?
Old Dec 9, 2013 | 05:39 PM
integrawillie's Avatar
Default Skunk2 Pro 2 Cams..This look right?
I purchased a set of used Pro 2 cams off marketplace a week or so back. The intake cam looks as it should (at least from what I expect), but the exhaust cam looks odd to me. On the back side of each vtec lobe there are is a dip just before the base circle. I don't know much it matters considering how violently it looks like the lobe opens the valve ( I can't believe how steep the angle is). Is this normal wear for these things? Like I said, I see no dips on the intake cam at all. Everything looks to be smooth.
Old Dec 9, 2013 | 06:05 PM
Bouckaroo's Avatar
Default Re: Skunk2 Pro 2 Cams..This look right?
Dips? are talking about the fine scratches that are there or the grooves in the cam that seperate the lobes? Or the little nicks on the edges?
Old Dec 9, 2013 | 06:38 PM
Natural Aspirations's Avatar
The cams are damaged, ask for a refund.
Old Dec 9, 2013 | 06:46 PM
The dips are right before the the lobe goes back to the base circle.
Old Dec 9, 2013 | 06:48 PM
Well that is upsetting to hear that they're damaged. I will contact the seller about these I suppose.
Old Dec 9, 2013 | 07:21 PM
negusjuda's Avatar
were these in a h/f series engine
Old Dec 10, 2013 | 03:41 AM
These are the b series cams.
Old Dec 10, 2013 | 05:15 AM
4piston's Avatar
Get your money back on those.
Old Dec 10, 2013 | 09:47 AM
Thanks for the advice everyone. I have contacted the seller, and he has been very cooperative. Will be in the market for yet ANOTHER set of Pro2's it looks like
Old Dec 10, 2013 | 11:19 AM
They can be repaired BUT if a refund is an option I would certainly go that route first.
eljah0426
14
Nov 6, 2011 01:19 AM
SonicB
Jul 21, 2010 01:12 PM
zap
10
Jun 18, 2006 11:31 PM
Savv
Dec 23, 2004 01:01 PM
