1992 Honda accord EX misfire till 2k RPM(then it drives good) HELP PLS!!
Old Dec 9, 2013 | 04:22 PM
Bruno Teixeira's Avatar
Icon6 1992 Honda accord EX misfire till 2k RPM(then it drives good) HELP PLS!!
i just the car about a month now!! I need some HELP!!PLS!!
Old Dec 9, 2013 | 09:08 PM
holmesnmanny's Avatar
Default Re: 1992 Honda accord EX misfire till 2k RPM(then it drives good) HELP PLS!!
You can start by cleaning out your egr ports.
https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-2002-accord-faq-1664547/
You can use this thread here
http://home.comcast.net/~em-engineering/T2T013.pdf
Old Dec 10, 2013 | 02:51 PM
i all ready clean Egr ports!! at the idle control valve !! but thanks for the tip!! anything wlsw that i can do ? do you think that a oil leak on my distributor can make that happen? thank you once again for the help!!
Old Dec 10, 2013 | 03:46 PM
Suma's Avatar
The EGR ports are on the manifold under the fuel rail. If that is what you cleaned then disregard this.
My 95 ex was spuddering between 1500-2300 rpms. Every mechanic had his own theory on the problem.
Turned out to be egr ports that took about an hour to clean.
Old Dec 10, 2013 | 09:49 PM
distributor cap, distributor rotor, spark plugs, spark plug wires, oxygen sensor ?
it is possible for oil inside of the distributor to cause the ignitor to start going bad, if that is what is happening however you haven't really given any indication as to exactly what is happening except that it seems to drive good after 2k.
sharaaz2001
Nov 18, 2016 04:01 AM
CompuRIP
Aug 20, 2008 05:59 AM
jimby452
Dec 7, 2004 03:31 AM
TedR719
Dec 7, 2003 10:08 AM
3WheelGTi
Dec 4, 2003 09:06 PM
