215/70/15 studded on '02 V6 accord
Old Dec 9, 2013 | 11:03 AM
SlamsItIn's Avatar
Icon2 215/70/15 studded on '02 V6 accord
I recently got a set of Nokian nordman-2 studded winter tires size 215/70/15 for FREE. Would I run into problems running them on my stock suspension 2002 v6 accord 15" rims?
Old Dec 10, 2013 | 01:38 PM
TunerN00b's Avatar
Default Re: 215/70/15 studded on '02 V6 accord
What is the correct tire diameter for your car? Those are 26.9" diameter tires, which sounds rather large for an Accord, but if that is within 2% of your original size then you should be fine.
Last edited by TunerN00b; Dec 12, 2013 at 07:00 PM. Reason: Doc is correct. I typoed a number.
Old Dec 11, 2013 | 02:31 AM
engineerings's Avatar
The rim size is the same i think up sizing wont be problem
Old Dec 12, 2013 | 02:50 PM
doc@tirerack's Avatar
Stock tires (205/65R15) average 25.5" in diameter, and the 215/70R15 will average 26.9". I'd expect a little rubbing when the car goes over big bumps (compressing the springs fully), and you also may see the ABS light flicker or the system have issues as you are more than 5% over what the car is programmed for.
Since you're only paying for installation, it's your call on if you want to experiment with them or not.
accord 2005
Nov 8, 2011 06:27 PM
z395civic
Nov 18, 2009 02:42 AM
z395civic
Jul 5, 2009 10:25 AM
Oyrein
Apr 9, 2006 09:17 PM
jmk2888
Nov 8, 2005 11:00 AM
