3g surging idle fix - check this before you spend money!
Old Oct 27, 2002 | 11:25 PM
knightm3's Avatar
Default 3g surging idle fix - check this before you spend money!
Unscrew the two screws from the fast idle valve, shown circled in the image above, and remove the metal lid. [I used a #1 Philips head.]
Inside you'll see a beige plastic valve with a spring assembly running through it. This plastic valve is threaded and must be securely tightened in order for the motor to idle correctly. In my case, the plastic valve had completely unthreaded itself, and was sitting loose. There are ridges along the side of the valve into which a flat-blade screwdriver can be used to tighten it.
rpmraper
Jun 11, 2011 10:53 AM
BlUAc
Nov 23, 2006 07:11 AM
Mike1486
Sep 23, 2004 06:20 AM
onyx00
Apr 30, 2003 05:51 AM
