Weird Idle after rebuild
Old Dec 8, 2013 | 04:40 PM
jdmmugeneg6's Avatar
Default Weird Idle after rebuild
Hey HTers, need some help here. Here is all relevant info about the build:
LS/V
ITR Cams
Buddy Club Cam Gears
LS Rods
ITR Pistons
Stock Injectors
Fuel Rail
B&M FPR
Dual Valve Springs
Titanium Retainers
Skunk Pro Intake Manifold
Recentely installed the cam gears and cams. Changed the HG and timing belt. Added the fuel rail and FPR. Started it up after fixing a bad ICM in the dizzy and here is what is happening:
Idles at like 2300 RPM even after warmed up. When I press the gas, it will drop almost to normal then back to 2300 or so. When I plug the FIT and IACV holes inside of the TB, will drop to 2000 RPM. Tried another ECU and no change. Throwing no CELs and everything else looks and sounds normal with the exception of that.
Any ideas? Any help would be greatly appreciated!!
Old Dec 8, 2013 | 04:43 PM
10psiLsEf2's Avatar
Default Re: Weird Idle after rebuild
Vaccum leak possibly.
Spray water around all vaccum hoses and around intaje manifold to cylinder head mating areas.
Old Dec 8, 2013 | 05:54 PM
Thanks, ill check it out. I have heard people use carb cleaner, is that better than water?
Old Dec 8, 2013 | 06:32 PM
ALLMOTORFTW1's Avatar
use soapy water
Old Dec 8, 2013 | 06:58 PM
10psiLsEf2's Avatar
Water is good enough since its no combustable.
The engine will stumble if theres a leak.
Carb cleaner will work but ive seen it go wrong due toan arcking plug wire
Old Dec 8, 2013 | 06:59 PM
10psiLsEf2's Avatar
Soapy water wont help.
You want soapy water to find positive pressure leaks. Like a tire.
Vaccum wont make it bubble.
Old Dec 8, 2013 | 07:23 PM
Got it! Didn't think about that. So as the little bit of water gets sucked in the motor will stumble a little?
Old Dec 9, 2013 | 04:33 PM
10psiLsEf2's Avatar
Yes
Old Dec 12, 2013 | 03:54 PM
Tim Limbrick's Avatar
I'd check for a vacuum leak also, but you may be running rich too. try a fuel cleaner and make sure the idle adjustment is set correctly. check chilton for specs
Old Dec 16, 2013 | 04:12 PM
Well, like an idiot, it seems like I had the MAP and TPS plugs backwards. After switching these I have a 750 idle but it is weird. Here is what I am experiencing:
1. Rough idle
2. Bogs when revving
3. White strong smelling exhaust (LOTS!!)
4. Fuel Pressure gauge shows like 80PSI!
5. B&M FPR won't adjust
So, I assume the rich condition is causing the weird idle, bogging, and exhaust. Could my B&M FPR be stuck open? When I try to adjust, nothing changes. First start up with this setup by the way.
Old Dec 17, 2013 | 04:43 PM
Anyone??
Old Dec 19, 2013 | 04:15 AM
Old Dec 19, 2013 | 01:19 PM
jdragon1974's Avatar
I would try putting a stock fpr on there. If it changes then you know it is a bad fpr.
Old Dec 19, 2013 | 02:28 PM
Yeah, trying to find one now.
Old Dec 19, 2013 | 07:02 PM
whitesihatch's Avatar
tps calibrated? change that fpr asap and let us know bud
91 DA Revived
Mar 8, 2012 08:24 AM
91CR-XSiR
Nov 8, 2009 07:48 PM
lsvtek9
Mar 1, 2008 06:52 AM
escourt23
Dec 15, 2005 06:59 PM
