FS/FT 1996 del sol si
$2750Canadian 1996 del sol SI Power windows,manual locks, 4wheel disk brakes
car is obd2(A) with no codes or pending codes
all stock except a couple of minor modifications
call or text 352-817-nine7one0
currently has a y7 swapped in since it was all I could find when I needed this car to be running
daily driver of mine for 2+ years
mileage is about 151k (253km) on the body about 80k on the motor
Timing belt,water pump and tensioner is less than 10000 miles old
New cv axles within the last year
New Alternator
new struts all around
rear sway bar end links and rear lower control arms
Plenty of other things replaced and repaired as I have owned it. Always has regular maintenance done oil changed every 3k
What it needs is some paint and body work currently only partially painted, No ac needs condenser and lines, driver seat is torn
also comes with all extra honda parts I have collected like complete passenger door guts ac compressor+bad condenser but with fan some interior pieces and other stuff
New Alternator
ef0cmacro
Jul 26, 2014 11:49 AM
