spark plug pics, what happened here
Old Dec 7, 2013 | 04:45 AM
blackeg's Avatar
Default spark plug pics, what happened here
so my lsvtec lost a bunch of compression in the #1 cylinder and started loosing oil. here are the plugs in order from 1,2,3,4 from top to bottom. motor was actually running rich, wideband readings were high 13s cruising and mid 12s wot
might rip the motor apart over christmas, just trying to see what your thoughts are so i can take corrective action for the next build
Old Dec 7, 2013 | 05:59 AM
jimmysxxl's Avatar
Default Re: spark plug pics, what happened here
that doesnt seem like mid 12 wot to me tbf. I bet someone more experienced will chime in though
Old Dec 7, 2013 | 06:11 AM
98vtec's Avatar
moderator emeritus
#3 porcelain looks to have a different color tint to it and the plug base looks a good bit darker. That's about all I can tell from that angle and focus.
Needless to say, low compression and using oil can only be a couple things.
Old Dec 7, 2013 | 07:03 AM
blackeg's Avatar
afr was verified by multiple calibrated widebands. additionally, the motor in there now has plugs that look great/appropriate for the wideband readings. the #3 had an enrichment of 2 in the neptune settings
the exhaust valves are all white and evenly colored, but egt never saw above 700c
i was thinking that coolant was entering the cylinders and washing some of the carbon off the basering...
Old Dec 7, 2013 | 12:16 PM
blackeg's Avatar
took it apart today. there was a fair amount of milky **** in the oil pan im assuming was coolant and oil mixing.
here is the head, cyl 1 at the top.
the #1 cyl intake side. all cyls have some of these marks at the top, they just barely catch the fingernail if at all. the pistons have some matching scratches between the top of the piston and the top ring. none of the rings were scored up on the edges, and none of the ringlands were broken or cracked
i found a few of these flakes in the block. none of the bearings were worn through the silver coating so im not sure where this came from. disgregard the sharpie arrow, the block had a spun rod before i bought it, but it was machined since and im using a different crank and rods
another look, intake side cyls 2 and 3. none of the cyls had vertical scoring that caught my fingernail and ran the entire length of the bore
exhaust side #1 cyl before i cleaned it. i noticed the clean spot up top where there is usually some carbon built up
Old Dec 8, 2013 | 05:22 AM
wreckeddc4's Avatar
I've seen those marks before on boosted stock piston engines when the ring lands break. They push out with cylinder pressure just like the rings and the sharp edges cause the score marks. Since it's already apart pull the pistons out and see what's going on.
Old Dec 8, 2013 | 08:50 AM
blackeg's Avatar
here is the piston in the #1 cyl that had the low comp and most marking.
intake side
exhaust side
piston was removed and i just wiped it quick with a shop towel/brake cleaner.
rings were clocked to oem positions upon assembly 12k miles ago. they rotated when i cleaned the piston.
im just happy to have a camera that works decent since i got a new phone
follie gatts
Jun 4, 2011 10:34 AM
Hello Honda Tech
Jun 17, 2010 05:44 PM
DriveSideWays
Aug 22, 2004 07:19 AM
Quitripin
16
Aug 18, 2004 09:20 PM
