Need A Picture for Broken Wiring Connector Help!
Greetings!
I just finished replacing the head gaskets on a 1995 Accord V6, and while I was taking things apart, I accidentally destroyed the wiring harness to the transmission shift control solenoids on top of the transmission.
Having everything finished I went to rewire it without a connector, and found that the wire colors were different. On the solenoid side, there is a green wire, and I believe a blue one, however on the wiring harness side they are green and yellow. I figured the green would at least go with the green one, so I wired it up that way, because I could NOT find a diagram or any info anywhere.
Sure enough, now check engine light pops on with automatic transmission problem. I may have made bad contact or just swapped the wires.
If someone has this engine could you please look under the intake tubing and post a picture of the gray connector, or at least tell me which wires go to which? Thanks!
bassysingh
Sep 7, 2011 06:24 PM
EFLander
May 26, 2010 03:50 PM
vtecn8ive
11
Nov 8, 2005 07:56 PM
