hyrdo clutch kit work with a jdm b16 xsi cable tranny?
does anyone know if 94-01 integra hydro clutch kit will work with the jdm b16 xsi cable tranny? cause know some of the spindle on the tranny are smaller. i put the clutch on my cable spindle and it looks like it will work but just want someone to confirm before i install everything.
Yes I have a hydro clutch on my cable tranny, if you tried the disc and it fit
your good because you would be able to see if it wont work.
it will work but the bushing/bearing that slides over the transmission shaft is different. There are tabs on the hydro throw out bearings that slide over the clutch fork to hold it in place… the disk and the plate are the same.
so the throwout bearing is different?
SiBuddy00
Jun 21, 2005 07:57 PM
jumpmann23
Apr 5, 2003 06:50 PM
