00-01 ITR Cluster in 95 Integra
Old Dec 5, 2013 | 12:29 PM
Tom_Chooch's Avatar
Default 00-01 ITR Cluster in 95 Integra
Ok so I just swapped a 00-01 ITR cluster into my 95 GSR. It has an obd-1 backing but I wanted to keep the 98-01 style placement of the dummy lights, so I decided to repin the cluster harness.
I got everything in the perfect spot, however the door ajar light is reversed ONLY with the ignition off (stays on with door closed, turns on when door opens) with the ignition on it works properly.
This was a simple 3 pin swap, I have no idea why the lights stays on with the ignition off... Anyone have any ideas?
Old Dec 5, 2013 | 11:56 PM
PaulMc's Avatar
Painfully Stupid
Default Re: 00-01 ITR Cluster in 95 Integra
If you don't find an answer in here, try a more appropriate forum, such as misc/tech or even lighting forum. It sounds like you made a petty mistake somewhere during your wiring that you're not seeing.
Old Dec 6, 2013 | 10:36 AM
Todd00's Avatar
I said I don't want a title!
meow. I miss our cat threads.
Old Dec 6, 2013 | 11:36 AM
Tom_Chooch's Avatar
Will have to recheck it, not exactly sure how something like this could happen though.
I'll try looking in a more appropriate forum, my apologies for posting this in here.
em2power
Honda Civic (2001 - 2005)
Dec 5, 2008 08:21 PM
HondaIntegraGSR
18
Dec 12, 2006 06:10 PM
95-EJ1
Feb 14, 2006 02:16 PM
ToiletFetusSushi
Oct 29, 2004 12:34 PM
metal-x
May 24, 2004 11:12 AM
