Selling Rebuilt JDM B16A **Near Wilkes-Barre, Pa
B16A
P30 pistons, Hastings rings
King main bearings, Topline rod bearings, new water pump, and all new gaskets. Bottom end was completely stripped down at Exton Performance in Canadensis, Pa...receipts and spec sheet from the shop included with sale
Top End:
95 GSR head, GSR cams
Edelbrock performer x intake mani
Stock injectors and fuel rail
Arp head studs
Cometic head gasket
Edelbrock Mani gaskets
68mm throttle body
Gates timing belt
Stage one exedy clutch
Ys1 tranny(not 100% sure if it's the long geared or short geared)
Gsr starter
2 new cv axles
Chipped p28 vtec crossover at 4500 redline at 8500, 2step at 3800 tuned on crome.
Everything for the swap into a da9 Teg is included besides shift Linkage, clutch cable, and the distributer since it went bad.
Only 75 miles on motor since rebuild so the breaking in process will need to be continued.
I'm asking 2100 obo for the whole swap or trades for f23 bottom end, h22 or h23 heads, or any other h/f series parts I'd be interested in plus cash on your end unless value is equal to my swap.
Top End:
Arp head studs
Cometic head gasket
68mm throttle body
Gates timing belt
Gsr starter
2 new cv axles
anothersickhatch
Jun 8, 2006 01:01 PM
