Cold/hot air adjusting knob doesnt adjust?
Old Dec 4, 2013 | 03:59 PM
Meraut's Avatar
Default Cold/hot air adjusting **** doesnt adjust?
Hey guys, i have a 92 honda accord and the cold/hot air adjusting turn **** on the dash doesnt work, it doesnt click like it used to just freely turns without resistance. Anyone know how i can fix this?
Old Dec 4, 2013 | 04:22 PM
GhostAccord's Avatar
Default Re: Cold/hot air adjusting **** doesnt adjust?
There is a wire cable that attaches to the heater-A/C control unit from behind. It goes from the control unit through the fire wall and attaches to a valve in the heater core inlet hose in the engine bay. You can check the connection in the engine bay easy enough. It is located below the intake manifold near the fire wall. The connection on the control unit itself is a bit harder to get at. You have to remove it from the dash.
Old Dec 5, 2013 | 06:02 PM
dirty-rob's Avatar
ive seen times where the cale breaks off the end of the ****,and i also seen where the **** breaks and ill just spin around the shaft,and ive also seen the heater valve in the engine bay rust and get stuck you can turn it by hand if you need to
Old Dec 5, 2013 | 11:08 PM
NY state of mind's Avatar
Most likely just the ****, the cables and valves can fail but are far more durable than the plastic **** which has surely turned brittle. Wiggle the **** while pulling toward you, once off check to see if it is cracked in any way or if the metal "D" retainer has stayed attached to the heater controls ( this is the part that affixes the **** to the controls). If you need to replace it they're pretty cheap at autozone and look fairly refreshed when you replace the pair http://www.autozone.com/autozone/par...2_179467_2826_
mayfly
Dec 10, 2009 08:01 PM
philkehn
13
Sep 21, 2006 12:02 PM
crxtuner69
Oct 16, 2005 07:28 AM
31flavorscivic
Nov 12, 2004 09:35 PM
Pee Wee
Jul 9, 2004 09:59 PM
