97 ek hatch turbo lsvtec built!!! 607hp
Up for sale is my 97 turbo lsvtec, this car is extremely fun to drive an have had a blast with it! The car has 12,069 original miles! Clean title. Always garage kept, I've built this car from the bottom to where it is now. I've only put 700 miles on the whole setup, this car only gets driven on the weekend. This is truly one great car an the new owner will see I'm asking 10,000 obo only reason for selling is because I am soon to start a family and the money would really be needed please contact me at 305-877-6617 to set up an appointment to see the car.
Shell:
1. 6 point roll cage
2. Ukdm cluster modded
3. Boost, oil pressure, a/f gauge
4. 15x8 wheels
5. 195-50-15 rear tires, 225-50-15 drag radials front tires
6. Traction bar
7. Blox drag suspension
8. Skunk2 camber kit
9. New rack an pinion
10. All bushings an ball joints changed
11. H.i.d lights
12. Rear ctr tail lights
13. Carbon fiber hood needs clear coat
14. Carbon fiber duckbill needs clear coat
15. Power windows
16. 2000 front end conversion
Turbo kit
1. Plm top mount
2. Plm down pipe 3 inch
3. Precision 6262 t3 .82 a/r turbo
4. Precision 46mm waste gate
5. Precision 750 hp intercooler
6. Satin black 2.5 inch intercooler piping with 4 ply couplers
7. hks bov
Fuel system
1. Full blown dual pump hanger
2. Dual 255 walbro pumps
3. 10an feed steel braided line
4. 6an return steel braided line
5. Aem fuel rail
6. 1600cc five 0 injectors
7. Aeromotive fuel pressure regulator
8. Fuel lab 10an fuel filter
Engine
Type R head:
1. Skunk2 stage 3 cams
2. Skunk2 l.m.a
3. Ferrera springs and retainers
4. Ferrera valve guides
5. Ferrera 5000 series valves
6. Fully ported head by Sfl machine
7. Golden eagle cam gears
8. Str intake manifold
9. Bdl 72mm throttle body
10. Omni 4 bar map sensor
11. Mishimoto radiator with dual fans
B18b Block:
1. Mahnley 10.2:1 compression pistons 81.5 mm
2. Mahnley h-beam rods
4. Balanced an micro polished oem crank
5. Acl rod an main bearings
6. Bored .5 mm over, honed, decked.
7. .40 cometic head gasket
8. Arp head studs
9. New type r oil pump
10. New oem water pump
11. New oem gsr timing belt
12. New oem tensioner
13. Bwr Oil catch can
14. Avid motor mounts
Transmission:
1. Stock ls transmission (freshly rebuilt)
2. Stage 5 competition clutch
3. Stock axles with warranty
Shell:
4. 15x8 wheels
6. Traction bar
11. H.i.d lights
15. Power windows
Turbo kit
1. Plm top mount
7. hks bov
Fuel system
5. Aem fuel rail
Engine
Type R head:
2. Skunk2 l.m.a
B18b Block:
8. Arp head studs
Transmission:
xbigpitax
Jun 10, 2014 08:33 PM
xbigpitax
Feb 14, 2014 01:35 PM
