Transmission & Drivetrain Gearboxes, Differentials, Clutches
chain like noise when in gear
Old Dec 3, 2013 | 05:30 PM
HondaLuv3r4Life's Avatar
Icon2 chain like noise when in gear
My 06 sedan makes this noise that can only be described as the sound of a rotating chain. Happens only when clutch is out in any gear. Car currently has almost 149k on it. Any ideas?
Old Dec 4, 2013 | 09:19 AM
Aquafina's Avatar
Default Re: chain like noise when in gear
A bearing, likely the mainshaft bearing in the clutch housing.
Old Dec 6, 2013 | 08:59 PM
doesn't that get replaced if i put a new clutch kit in it? Because it also shifts rough as hell, no grinding(yet), and often doesnt want to go into first without fighting it sometimes.
Old Dec 6, 2013 | 09:26 PM
slowcivic2k's Avatar
No, that part has to be serviced from inside the transaxle. What type of oil and how hard have to been on it. Like Aqua said, a bearing noise is suspect out of gear. The noise may dissipate while in gear because of the load on the bearings.
Old Dec 7, 2013 | 10:18 PM
where is the transaxle located? not too knowledgeable about this. Hopefully not inside the tranny.
Old Dec 8, 2013 | 02:39 PM
Aquafina's Avatar
Transaxle is another word for transmission.
The transmission has to be removed and disassembled.
Old Dec 8, 2013 | 03:57 PM
Do you happen to know if it's an expensive repair? I'm on a SUPER tight budget and can't afford tranny work can barely afford to fix clutch.
Old Dec 9, 2013 | 08:11 PM
In a shop you will spend a lot of money to have work done like that. It might be time for you to start DIY repairs.
Most clutch jobs run from 500-1000 dollars, add additional charges for tearing down the transaxle and inspecting it. It will add up fast.
Old Dec 11, 2013 | 09:24 AM
Aquafina's Avatar
It's not too bad, but it is more than a clutch.
OneFire
Aug 7, 2009 04:24 PM
itsLOUiSduh
Mar 9, 2009 08:35 PM
carsaregood
May 11, 2006 11:14 AM
TiredToyotaDriver
Jan 14, 2006 07:26 PM
Loki12
Aug 7, 2005 09:36 AM
