Porting downpipes and manifolds
Old Dec 3, 2013 | 04:38 PM
a267mm's Avatar
Default Porting downpipes and manifolds
What are you guys using, I started using some Mac tools metal bits but what are you guys using to polish and what grits I'll post some pics up tomorrow of what am working on
Old Dec 4, 2013 | 09:16 AM
HellaFab's Avatar
Default Re: Porting downpipes and manifolds
I have just been doing rough porting with a single cut quality carbide at medium RPM.
The markets I am targeting arent typically willing to pay the $ for a fine port.
That being said, I want to get another larger diameter carbide for my work... the one i have works amazing, but the small diameter and short shank make it difficult to get into some spaces.
Old Dec 6, 2013 | 04:53 AM
weiRtech's Avatar
OG Fabricator
I use a variety of carbide burrs. it depends mostly on how tight corners are. I will try to use a larger one if I can that has a ball end. if I need i'll go to a radius cone style but keep at least a small ball end. after that i'll use a 180 or 120 grit barrel style flap wheel. 2" is a good size for 3" downpipes. too big for a head flange but you might be able to find smaller diameter ones.
the problem you face going with longer burrs is they chatter a lot more. always try to keep it as short as you can in the grinder.
aaron
Old Dec 7, 2013 | 02:53 AM
jimbo slice's Avatar
Or slow the grinder down considerably.... That's how I keep my long shank burrs from whipping around on me.
OP, are you looking to just clean up the pipes or are you after the bling-bling like Toxic Fab?
Old Dec 7, 2013 | 08:47 AM
a267mm's Avatar
cleaning pipes and then polishing them inside for a smooth transition what grits should i use after and which styles
siblues
Welding / Fabrication
Sep 16, 2014 09:09 PM
FMN716
Oct 11, 2010 10:28 AM
wkd astra van
Jul 29, 2009 09:30 AM
ladius
Oct 23, 2005 01:11 AM
RedTT
Mar 4, 2005 03:25 PM
