What will cause a single injector to lose power?
I was driving home the other night and all of a sudden CEL comes on and car is misfiring.
Injector #1 is not firing. Not getting power. I've swapped injectors, plugs, wires.... Then I unplugged injectors 1 by 1 and found its not firing.
Is there a basic ground I can check, ECU connectors? Common wire spots that may cause issues.
I havnt touched the car in any way for this to happen. Everything is stock.
1998 R with 209XXX
1998 R with 209XXX
Its' either a bad injector (clogged or dead), bad wiring, or a bad ECU. Swap the injectors around to see if the problem follows the injector. If it doesn't then it's either wiring of the ECU.
lsvtek
15
Jul 10, 2012 02:28 PM
